Results 1 to 3 of 3
Thread: First test help
    Oct 2013
    Nebraska
    Default First test help
    Hello Forum,
    Any help would be appreciated. I struggled with chemicals last year and would like to keep it clean this summer!
    Above ground 24', Vinyl, 16.500 gal. Hayward Sand filter S210T2580, Hayward 1/5 hp pump - CA02-15
    hth 6-way drop test results:
    Chlorine test - clear, non existent?
    pH - 8.0
    Alk - 150+ ppm (stopped after 15 drops)
    Calc Carb - 150+ ppm (stopped after 15 drops)
    Thank you!
    round AG pool
    Default Re: First test help
    Hi!
    If you have nothing but clear on the chlorine test, you have no chlorine, too high pH.
    As for Alk, you should have kept going. Generally, below 200 is OK for vinyl.
    For Calcium, 0-400 is normally OK. Concrete pools are recommended to be 200-400ppm, but vinyl can range from 0 to 500.
    HOWEVER, I suspect that your high pH and high alk go together and you need to add acid to bring pH down and bleach to bring FC up.
    You COULD use Tri-chlor tablets in a floater for a while--I suspect your CYA, aka Stabilizer is very, very low, and Tri-chlor add chlorine, acid and CYA all at the same time.
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. 1st Test with PS234 W/ copper test
    By JJSZABO in forum DPD-FAS based testing
    Last Post: 07-07-2006, 04:15 PM
  5. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
