Thread: Free Chlorine Level, too high?
    mommak is offline Registered+ Thread Analyst mommak 0
    May 2014
    Michigan
    Default Re: Free Chlorine Level, too high?
    As of now my CYA is still less than 30. My test solution was barely cloudy. I could still see the black dot in the bottom of my test kit.
    And yes, I have the k-2006 test kit. This is what I have been using.
    Intex AG, 18' x 48", 7,500 gallons,
    Intex Sand Filter-SF 20110
    K-2006 Test Kit
    Ok. So, even though a chlorine reading of 10ppm is a little high for a pool with CYA less than 30ppm, (unless you are shocking the pool), it will come down on its own. Low CYA pools don't hang on to chlorine very long on hot sunny days.
    Nothing to worry about. If you swim today while the chlorine is at 10ppm, just wear an old swimsuit. It won't hurt you at all.
    May 2014
    Michigan
    Thank you Watermom. My 9 year old is so excited to get in the pool. Too cold for me, it's only 69 degrees. We placed the solar cover on last night and it kept the temperature from last nights reading. Hubby is hooking up the solar panel as I type.
    K-2006 Test Kit
    69 is way too cold for me, too! You'll be surprised how fast the solar panel will warm the pool up especially with also using the cover. Have fun!
    (Thanks for editing your sig.)
  1. how to get chlorine free level correct?
    By rajung in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-06-2013, 10:25 PM
  2. Very Low Free Chlorine Level.
    By jytchu in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-24-2013, 04:32 PM
  3. No Free Chlorine Level
    By dltodaro in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2012, 06:41 PM
  4. Clear Pool but cannot maintain free chlorine level?
    By Mr.Mooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 08:47 PM
  5. How high can Free chlorine be in SWG
    By JazzMan2010 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-10-2010, 03:33 PM
