Results 1 to 8 of 8
Thread: Cloudy Water
    Default Re: Cloudy Water
    I think you need to quit adding so much stuff to the water! No more floc, clarifier, metal eliminator, Fiber Clear or anything else except bleach and maybe Borax if your pH is still low.
    Several questions that I have:
    --What is the source of your fill water?
    --Do you have metals in the water?
    --Have you used algaecide and if so, what type?
    If you can't spring for a Taylor K2006 kit right now, can you at least go to Walmart and see if they have the HTH 6-Way kit (NOT the 6-Way test strips). If they don't, at least pick up an OTO/Phenol Red kit (yellow and red drops). We can't really give any helpful advise without some good numbers from a drops-based kit.
    Repost and someone here will try and help you.
    Welcome to the Pool Forum!
    Jul 2011
    Burgin Ky
    CL Has been over 6 by OTO test all day. Showed over 10 on strips since Friday eve. still cloudy.
    Maybe the Baking soda?
    Jul 2011
    Burgin Ky
    3 Days now with chlorine above 10ppm. alk shows ok. stabilizer ok. with drops test well over 5ppm for chlorine. Its still blueish color. can see down maybe a foot till objects get fuzzy then disappear.
    If you can supply answers to some of the questions in my post above, it might help someone here have some better advice for you and help you figure out how to clear this pool up.
    Jul 2011
    Burgin Ky
    a post didn't show up. hmmm? oh well, I have city water. I dont know if i have metals in it. I did put several shocks in that had algaecide. I think they used copper in the shock.
    Are you able to get one of the kits from Walmart that I mentioned above? We really need some good numbers to be able to help.
    It sounds like the the 'green' is gone, but the pool is remaining cloudy?
    A very common cause of this problem is the oversized pump + undersized filter combination typical of AG pool packages. What happens is that the big pump forces the dirt (dead algae) THROUGH the little filter, AND also washes the sand out during backwashes.
    Do the "DE-test" on your filter to make sure it's actually working OK. If it is continued use of DE in a sand filter will help capture and filter out the fine particles causing the cloudiness . . . at the price of more frequent backwashing. http://pool9.net/de-test/
