The pool came with the house. I have no idea what brand. Its 15x30 and may possibly be a Namco brand. According to neighbors the homeowner bought it when the company was having a going-out-of-business sale.
Kevin
15x30 oval AG Pool. Hayward Power-Flo Matrix 3/4 HP pump. Hayward 16" sand filter. Taylor K2006 test kit.
Doesn't matter what brand it is. I was trying to find out if it was an inground gunite pool as you would need to raise the calcium level if that were the case. Since it is an AG pool, that isn't necessary.
One number you didn't list was CYA. Is this a freshly filled pool? Do you have a CYA reading?
(Please update your signature to show that you have a K2006. You can do so by clicking on the link in my signature below.)
I didn't do a CYA test. Is it really that important? The pool is not freshly filled. It was here when we purchased the house.
Kevin
Yes, knowing your CYA is one of the 3 most important numbers along with chlorine and pH. Go ahead and run that test and report your number. We need to know that to know what your chlorine levels need to be. More about the chlorine/CYA connection here: http://pool9.net/cl-cya/
If CYA is stabilizer, then the number is 0. I know that without running a test. I don't have any and won't be able to get any until Wed. Working 12 hour shifts kind of puts a damper on getting anything done on work days.
Kevin
There may be some in there from last year. Probably a good idea to go ahead and run the test.
New numbers are in!
Ch: 5.8
pH: 7.2
ALK: 70
CYA: 60
Going to go buy some stabilizer.
Kevin
