New numbers are in!
Ch: 5.8
pH: 7.2
ALK: 70
CYA: 60
Going to go buy some stabilizer.
New numbers are in!
Ch: 5.8
pH: 7.2
ALK: 70
CYA: 60
Kevin
15x30 oval AG Pool. Hayward Power-Flo Matrix 3/4 HP pump. Hayward 16" sand filter. Taylor K2006 test kit.
You don't need more stabilizer. A reading of 60ppm is plenty.
CoolI guess all my number are good. Would explain why my pool is nice and clear. You all have been very helpful
Kevin
Just make sure that you keep your chlorine in range per the Chlorine/CYA chart I linked for you back in post #6. If you dip too low, you'll risk an algae bloom. (We call that chart our "Best Guess Chlorine Chart." If you lose that link, you can always find it in either my or PoolDoc's signatures.)
One other comment -- use the 10mL water sample instead of the 25ml one. It will make your chlorine testing reagents last longer. You will multiply the number of drops by 0.5 instead of by 0.2.
Glad we could help. If you need us again, you know where to find us!![]()
Used wrong calculation for chlorine. My number is actually 14.5! I will hold off on adding chlorine for a day or so.
Kevin
