Results 1 to 10 of 16
Thread: chlorine level keeps rising
    May 2013
    Northwest Indiana
    Default Re: chlorine level keeps rising
    Just add the dichlor as needed to chlorinate your pool... It might take a few days or a week to get your cya to where you want it, but that's not a problem.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
    mommak is offline Registered+ Thread Analyst mommak 0
    May 2014
    Michigan
    Okay, I will follow the nightly regimen.
    Is there a point when chlorine levels can ruin a vinyl liner?
    My kids wanted to swim today, but I told them"no" due to the high Chlorine level.
    Intex AG, 18' x 48", 7,500 gallons,
    Intex Sand Filter-SF 20110
    K-2006 Test Kit
    Skip adding dichlor tonight and see what your chlorine level is tomorrow morning. (How much are you adding each evening?)
    May 2014
    Michigan
    I have been adding 1 1/2 cups. I did a quick test this afternoon, using the 3 way test (bought from Wal-Mart when we set up our pool in 2010). The color didn't look as bad as this morning's reading,but still much higher than it should be. I have been following the plan to the T. And following the advice from here.
    Tonight I will skip the dichlor. I hope that in the morning my FC will be lower after the sun was on the pool for over 6 hours today.
    K-2006 Test Kit
    May 2014
    Michigan
    Tested my pool today, I skipped adding the dichlor last night as recommended by Watermom
    FC = 11.5
    pH = 7.2
    CYA = less than 30 (even filled to the top I could still see the black dot)
    K-2006 Test Kit
    BigDave's Avatar
    Quote Originally Posted by mommak View Post
    I have been adding 1 1/2 cups. ...
    A smaller dose is probably appropriate, chlorine usage will go down as CYA builds. Just be sure FC stays above the minimum throughout the day.
    ... I have been following the plan to the T. ...
    No need to. You are discovering how to take care of the pool using your own judgment. This is really what "BBB" is all about. You found pH was too high - stop adding borax for a while. You found FC is too high - cut back on chlorine additions.
    You're doing great!
    May 2014
    Michigan
    Thanks BigDave,
    You said "Just be sure FC stays above the minimum throughout the day". What do you mean by this? Since my FC is 11.5, isn't that above the minimum already?
    K-2006 Test Kit
    BigDave's Avatar
    You are well above for now, but sunlight will bring it down soon enough. When we say minimum we mean minimum as per the Best Guess Chart:http://pool9.net/cl-cya/.
    Add enough chlorine (dichlor for now, bleach later) at night to end up at or above the Best Guess Chart minimum the next night before adding more. I know is sounds non-specific, it's supposed to. We try to teach pool owners to find what thier pool needs and respond to it: measure - adjust - measure - adjust ...
    BTW - chlorine is high but I think you'd be just fine swimming now - maybe wear old swim suits as high chlorine can bleach out swim gear.
