Results 1 to 8 of 8
Thread: Pool very dirty day after use.
    Default Re: Pool very dirty day after use.
    Chlorine levels don't stay consistent; it is normal for the level to drop during the day especially when there are swimmers. If your CYA level is low, it also makes it more difficult to keep chlorine in the pool.
    Why are you needing to refill so often? Are you backwashing after every time you vacuum or are you vacuuming to waste?
    Why so much dirt? Lots of kids going in and out of the pool? It is impossible to keep an outdoor pool pristine --- trust me. I try!
    Jun 2014
    A northeast state
    I was always told to vacuum to waste. Is there a better way? Remember, I've been given a lot of bad information. That is why I came here
    Kevin
    15x30 oval AG Pool. Hayward Power-Flo Matrix 3/4 HP pump. Hayward 16" sand filter. Taylor K2006 test kit.
    Jun 2014
    A northeast state
    Hayward sand filter, 18", I think.
    Kevin
    Just vacuum to your filter. You won't need to backwash it every time either. Just watch your pressure. When it rises 8-10psi over your clean filter pressure, then backwash. (Or if you notice a big drop in the flow at the return.)
    The only time someone might vacuum to waste is if they are picking up piles of algae or something like that.
    (Go ahead and edit your signature to add your filter info. You can do so by clicking on the link in my signature above.)
    BigDave's Avatar
    One additional suggestion: I have a foot bath that I place in front of the ladder. It keeps alot of grass and dirt out of the pool. I know because it's always filthy when I dump it.
    Jun 2014
    A northeast state
    Yes. We will be using the foot bath next time.
    Kevin
