Re: phosphates high? ph low
thank you, I will start with the Borax tonight and add a bottle of bleach one day at a time I guess. I have a taylor test kit, I just needed to replenish it which is why I went to Leslies. As long as the phosphates dont matter, I wont do anything about it i guess. They told me algae would bloom if I didn't add the phosfree. I will get the cya at leslies if its good.
thank you
16x32' rectangle 19K gal IG vinyl pool; bbb; jacuzzi sand filter; jacuzzi pump; 8hrs; Taylor 2000; utility water; summer: none; winter: vinyl / water bags; ; PF:6.3
