Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Salt water pool great but damaged my aluminum ladder anchors
FAQ
register
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
06-10-2014
05:57 PM
#4
PoolDoc
View Profile
View Forum Posts
Administrator
Quark Inspector
Re: Salt water pool great but damaged my aluminum ladder anchors
That would look best.
But you can simply cut out a rectangle about 36" by 8".
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Best concrete sealer
Dark brown stains in pebbletec finish
Water looks great but everything is off
By Lexifa in forum Pool Chemistry for Intex-type Pools
4
Last Post:
06-14-2013,
12:35 PM
Removing Damaged Brass Concrete Deck Anchors
By roddiaz1 in forum In-Ground Pool Construction and Repair
6
Last Post:
10-17-2010,
01:53 PM
ladder: anchors how high?
By us7sail in forum In-Ground Pool Construction and Repair
11
Last Post:
08-23-2006,
06:00 PM
Cloudy Water and Aluminum
By jma1_nemo in forum Testing and Adjusting Pool Water Chemistry
5
Last Post:
08-10-2006,
09:21 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
