Ryan, you're in a tough spot: you're new to pools and you have to clean up a swamp. That's not that easy for anyone, but it tends to be overwhelming to newbies. I can help make it easier, but not easy.
I'm going to try to dissect, and then explain, what's going on . . . and then give you some step by step directions.
OK. Let's start:
Working on vacuuming and brushing but it just makes the water greener.Perfectly normal . . . for a pool swamp.I backwashed and rinsed and put it back to filter and it seemed fine again pushing water through to the jets but this seems to be happening almost multiple times a day.
There are piles of algae (and maybe leaves and other stuff) on the bottom. If possible, it's best to vacuum these to "waste". That's a setting that sucks water into the pump -- like normal -- but then dumps it out the backwash line, rather than passing it through the filter. You may need to 'over-fill' your pool, before you do this. And, since you'll be vacuuming blind, it helps to have someone watching the discharge, so they can tell you if you are vacuuming 'goo' or need to move on ('goo' is dark green; not-goo will be cloudy water.)
The fact that your filter is having to be backwashed merely means that (a) your pool is a swamp, and (b) your filter is working to remove the goo from the water . . . but that it can only hold so much before it stops up.
As WaterMom told you, low pH is dangerous to your pool! It won't hurt you (it's not THAT low), but it will damage your pool. Because your chlorine is high, you need (a) a gallon of Walmart distilled water and (b) a BUNCH of borax - 6 boxes or more. When you get home with that, test your pH using a 50:50 dilution of pool water with distilled. If it's below 7.0, start adding borax, directly to the skimmer, 1 box every hour. Test before each addition. Stop when your pH is a little higher than 7.0.My pH was below 7 a mid to light yellow
You can't throw these away -- it's illegal to put them in the garbage. So, unless you have a friend to give these to, I'm going to disagree with WaterMom, and tell you to go ahead and use them -- but do NOT buy any more! Also, do NOT use them till your pH is 7.2 or higher: they are quite acidic.but I have some giant 3" chlorinating tablets that I purchased from Menards.
Having them in your skimmer will help your filter, since the concentrated chlorine off these tabs will be hitting the goo on the filter.
So, step by step:
1. Fix the pH before it damages your pool (any more?).
2. Physically remove all the 'goo' you can, by vacuuming to waste and using a leaf net.
3. Use up the tabs AFTER your pH is above 7.2. Do NOT buy more of these.
4. Never, EVER, let granular chlorine come into contact with the tabs: they do NOT play well together!
5. Complete these forms, so we can better tell what's happening and what you have:http://pool9.net/pf-pool-form/6. Prepare yourself for a long haul -- you are at the wrong end of a steep learning curve, and your pool is not going to pristine for a week or more. There may be some unpleasant surprises, once you can finally see all of the pool.
http://pool9.net/pf-hist-form/
