Results 1 to 10 of 17
Thread: New pool owner. Cya level over 100. No free chlorine detected....help
    Jun 2014
    Virginia
    Default Re: New pool owner. Cya level over 100. No free chlorine detected....help
    Hi Watermom and PoolDoc,
    Thank you for your help. I watched the Taylor demos and filled out the pool form.
    Watermom, I did a you suggested and got a cya reading of 80 which I multiplied by 2 to get the 160 I reported to you. I'm not sure it's that high though. I had the pool company here this afternoon to show me how to work the pump, chlorination, etc. They tested too and got a cya reading under 100 but they don't always do that test so I'm not convinced that their number is correct. They also added some muratic acid and showed me how to siphon off water if I choose to do that. They had a FC reading of 5+ and TA of 150 approx. as they hadn't written them down. I will test again tomorrow and report all those numbers. The pool looks blue and clear but smells like chlorine a bit. No one is trying to swim so we can see how long the FC holds. Thank you again so much.
    6.3k gal FG inground pool with cartridge filter. Solid cover. Trichlor feeder, K2006. PF=19
    Gotcha. I didn't realize that your CYA reading was from dilution. The fact that they got an FC reading of 5+ shows that your kit is better than whatever they are testing with. 5+ on a test kit that only goes to 5 means that it could be 5 or any number higher than that.
    When you post your numbers tomorrow, post FC and CC in addition to pH and TA. No need to run the CYA test again.
    Jun 2014
    Virginia
    Thank you. Here is what I got yesterday:
    FC: 8
    CC: .5
    PH 7.4
    Ch 270
    This chlorine ratio seems out of balance. What do you recommend?
    What is your TA reading? How does your water look?
    You are at the minimum chlorine level for your CYA. Take a look at this chart for more about the relationship between CYA and needed chlorine levels: http://pool9.net/cl-cya/ Go ahead and add some bleach now so your chlorine doesn't dip any lower through the day.
    Her TA was 180 a few days ago.
    Composite:
    TA = 180
    CH = 270
    CYA = 160
    Given a CYA=160, as long as your pool is algae free, you need to keep your FC between 8 and 16 ppm. Don't worry about CC, so long as it's only 1 drop of FAS (0.5 ppm with the 10 ml sample size).
    So, to respond to your question, your chlorine is fine, except a bit low.
    Given your high TA & moderate CH, you need to lower your TA a bit. If you would lower the pH to 7.4 or so, and retest TA to confirm. To lower, see http://pool9.net/ma/
    I looked at your data, and recalculated your volume as 6,300 based on the dimensions you provided. If the depth measurements were pool depth, rather than water depth, the actual volume is even less.
    Jun 2014
    Virginia
    Thank you, PoolDoc. I didn't see this reply before posting mine. I will lower the ph. There is not and hasn't ever been any algae as far as I know. The pool is approx 8000 gal according to my pool service company. I did not measure the depth and length, I just estimated. I will get an actual measurement and update it.
    It doesn't sound like you are concerned about my high cya number. I understand that having a high cya means keeping lots of chlorine in the pool. I'd like to have my pool water be as healthy as possible for my kids to swim in. Wouldn't using less chlorine achieve that? What do you recommend? Thank you.
    It is up to you. You can do a partial drain and refill if you want but don't totally drain it. OR, just keep the CYA at 60 and run the higher chlorine levels per the chart. It is fine to do so and your kids can certainly swim with no problems.
    Jun 2014
    Virginia
    Thank you, Watermom. So I added another gallon of Walmart 8% bleach early this morning and my pool service added some acid last week.
    Here are my numbers:
    FC 11.5
    CC .5
    Ph 8+
    TA 160
    CH 52
    I looked at the best guess chart but don't understand. For my high cya number, should I be aiming for FC of 8 to 15? What does the shock column mean? I need to have my pool swimable by the weekend. Would you advise me to drain some of the water?
    Thank you so much.
  1. Free Chlorine Level, too high?
    By mommak in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-07-2014, 01:43 PM
  2. how to get chlorine free level correct?
    By rajung in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-06-2013, 10:25 PM
  3. Very Low Free Chlorine Level.
    By jytchu in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-24-2013, 04:32 PM
  4. No Free Chlorine Level
    By dltodaro in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2012, 06:41 PM
  5. Clear Pool but cannot maintain free chlorine level?
    By Mr.Mooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 08:47 PM
