Need advice for replacement pool heater- Ours oil heater was "condemned".
I have a 20k gallon in ground pool. It’s called a Grecian, I think. 20x40. The pool is heated by oil. We had our oil company come to service the pool heater and they condemned it. It’s rusted through and can't be fixed. I am located on Long Island in NY.
In doing my research I see we can go 3 ways:
1. Replace the oil heater at ABOUT 6k-7k.
2. Switch to propane at ABOUT $5-6k. (This includes removing the old oil tank, disposal and pumping)
3. Switch to an electric heat pump at ABOUT $5k (also includes removal of oil tank).
I was told that an electric heat pump might be a great alternative. We have an electric panel by the pool equipment, so I know we do have to check if it’s a 50amp dedicated.
Does anyone have any advice as to where I can look for solid information on replacing the heater? Or if you have a heat pump and love it?
I need to research this and see what option might be the best. Any advice or direction would be GREATLY appreciated!!
