Thread: Need advice for replacement pool heater- Ours oil heater was "condemned".
    Jun 2014
    Long Island, NY
    Default Need advice for replacement pool heater- Ours oil heater was "condemned".
    I have a 20k gallon in ground pool. It’s called a Grecian, I think. 20x40. The pool is heated by oil. We had our oil company come to service the pool heater and they condemned it. It’s rusted through and can't be fixed. I am located on Long Island in NY.
    In doing my research I see we can go 3 ways:
    1. Replace the oil heater at ABOUT 6k-7k.
    2. Switch to propane at ABOUT $5-6k. (This includes removing the old oil tank, disposal and pumping)
    3. Switch to an electric heat pump at ABOUT $5k (also includes removal of oil tank).
    I was told that an electric heat pump might be a great alternative. We have an electric panel by the pool equipment, so I know we do have to check if it’s a 50amp dedicated.
    Does anyone have any advice as to where I can look for solid information on replacing the heater? Or if you have a heat pump and love it?
    I need to research this and see what option might be the best. Any advice or direction would be GREATLY appreciated!!
    Default Re: Need advice for replacement pool heater- Ours oil heater was "condemned".
    Whether a heat pump would be a good choice for you depends on how you plan to heat your pool. Heat pumps are best for WARMING pools when it's cool; they are NOT efficient at heating pools when it's cold.
    I'm not sure about the relative economics of oil vs propane.
    . . . membership upgraded.
    Jun 2014
    Long Island, NY
    Thank you. I was told, basically, the same as well. I was told that once the pool was up to temp the heaters work really well.
    But it still comes down to this: Does anyone have a place I can do some more research about this?
    grecian-shaped IG pool
  1. Replies: 0
    Last Post: 07-05-2013, 12:40 AM
  2. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  4. Skimmer replacement "circular weir" questions.
    By Socal_biker in forum In-Ground Pool Construction and Repair
    Last Post: 10-10-2006, 04:55 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
