What are all the chemicals you have used? Anything with copper in it?
"Should you worry?" Yes.
Green on filters is often either algae (not good) or copper (not good, either). You can find out by getting some bleach, some Vitamin C tabs, a couple of clear wine glasses, and some green sludge off your filter. Put a bit of the sludge in each glass, then add bleach to one. Add tap water + Vit. C to the other. If it's algae, the bleach will turn it brown. If it's copper, the Vit. C will cause the color to disappear or at least change.
. . . membership updated.
PoolDoc / Ben
