It's a good one. I prefer 100-125--but no higher with your pool.Originally Posted by Pinman24
It is low. I like to see 30-50--I normally prefer 30, but sometimes 40 or 50 is better. Especially if you have LOTS of direct sun. With your low pH do NOT, NOT, NOT use Tri-chlor tabs--they will lower it still further. You can get pure CYA. Add no more than 1/4 of what they recommend--It's easy to add more but difficult to get it out.
I feel the CYA is slightly low, Is it and What is the best way to increase this? Triclor tablets?
350 is still well within recommended range for your pool. 400 is the highest you should go before dilutiing it down. I wouldn't mess with it. Suggested range is 200-400 for your pool.
I feel the CA level are too high, I would like to see these numbers in the 180 - 220 range.
WHY, pray tell! Your T/A was too low you had to add to it. Why lower it more?? You are doing absolutely the wrong thing here.I have lowered the PH and started heavy areration with our waterfalls and spa jets.
Can't help you on the last. Sorry. I just don't know.Do I want to add Leslie's stain and scale enhancer? We did get some scaling on our cement rock sides, our pool as no tiles.
Any and all comments are appreciated.
Paul
