Aeration raises pH without raising Total Alkalinity, unlike other means of raising pH. That is its purpose.
Why would the CYA in Tri-Chlor be "inferior" to straight CYA? CYA is CYA. I have no problem with using Tri-chlor to raise CYA, when at the same time pH is high, because Tri-chlor will lower pH as well.
