Re: Jumping in AG pool from deck
Since you have an oval AG, keep in mind that the water pressure is greater on the sides than the end so if you have a lot of big adults doing cannonballs, I don't know if that might cause problems down the road but for kids it shouldn't be an issue.
Also keep in mind that tall adults are likely to hit bottom so make sure they keep their knees bent.
