Thread: Chlorine useage in pressure washer near pool
    Jun 2014
    Maine
    Default Chlorine useage in pressure washer near pool
    Can I use Chlorine Bleach in my pressure washer to clean my wood deck which is attached to the pool without ruining the vinyl liner?
    Default Re: Chlorine useage in pressure washer near pool
    Probably.
    But the sensitivity of the print on the vinyl varies from liner to liner even among lingers from a single company. I'd recommend soaking synthetic sponge in bleach, and then rubbing it against a small inconspicuous area of the liner to test. Better safe, than sorry!
    . . . membership upgraded.
    Largo, Florida
    You might want to dilute the bleach a little as well. Straight bleach can be hard on the rubbers in the pressure washer's intake system. No liner, but I use diluted bleach to pressure wash my pool decking. It's a good option because you don't have to worry about contaminating the pool with whatever other cleaning product you might have used.
