Thread: Intex SF20110 suction
    mommak is offline Registered+ Thread Analyst mommak 0
    May 2014
    Michigan
    Question Intex SF20110 suction
    I have tried looking for an answer to this question but have not been able to find one.
    I turned on my pump and the water coming into the pool seems fine, it's the suction from the other valve that is very weak. What kind of suction should you be able to feel? This would be the one that is supposed to be taking water from the pool and filtering it into the filter.
    Intex AG, 18' x 48", 7,500 gallons,
    Intex Sand Filter-SF 20110
    K-2006 Test Kit
    BigDave's Avatar
    Default Re: Intex SF20110 suction
    Shouldn't we have the same volume of water leaving the pool as returning to the pool? If the return is fine doesn't the oulet have to be fine too?
    May 2014
    Plano, TX
    Outlets are designed to "feel" like it has low flow. This to prevent entrapment.
    May 2014
    Michigan
    Okay, when the pump is on I have a good flow of water coming into the pool. I felt the skimmer and it just didn't have much of a suction so I thought that something was wrong.
    Thank you for your help. Still learning about pools and all it takes to maintain them.
    K-2006 Test Kit
    The learning curve is most steep at the beginning. You're doing great. You will soon get more familiar with your pool's behavior and things will become second nature to you!
    May 2014
    Michigan
    Thank you. This pool forum has been a wealth of great information.
    K-2006 Test Kit
    Quote Originally Posted by mommak View Post
    You're welcome! That is why we are here!
  1. Intex Sand filter suction air leak or...???
    By BlueCorn in forum Intex-type Pool Setup & Operations
    Last Post: 06-06-2013, 10:03 PM
  2. Poor Skimmer Suction and Good Main drain suction
    By teachone in forum In-Ground Pool Construction and Repair
    Last Post: 06-14-2012, 02:06 PM
  3. Suction
    By Rkh3 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-18-2011, 09:35 PM
  4. Suction, Where did it go?
    By Orkalovesfood in forum Pool Equipment & Operations
    Last Post: 08-07-2006, 06:25 PM
  5. Too much suction !!
    By karenkr in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-25-2006, 11:46 AM
