pauster
I'd really like to understand how these motors work in general ...
So a standard motor (under reasonable conditions, i.e. while hooked up to pool) will always run at maximum power and constanly draw the rated amps ? Even if the mechanical resistance of the pump varies due to e.g. a more or less clogged filter the amp draw is the same ? I am not questioning it, just want to understand the basics ... This would mean that the pump "tries to get the maximum flow it can achieve at the given head" and consumes always a constant amount of energy per unit of time.
More or less. The current will change slightly (<10%) with load but this can only be measured so as a first order, just use the rated amps. Also, the impeller of the pump is designed such that the motor operates near at the service factor load (i.e. full load)
The biggest impact to the pump with load changes is it's efficiency. How much work it does vs. the braking HP (BHP = HP * service factor) or energy use. Generally, if you are in the range of 45-65 feet of head, the energy efficiency of the pump may vary from 40% to 50% peaking somewhere in the middle depending on the HP of the pump. BHP efficiency can be determined by (GPM * Head (ft))/(3960*BHP). Energy efficiency is similar = (GPM * Head (ft))/(5315*KW)
Energy efficiency is a bit less than BHP efficiency depending on the pump.
So you might ask where does the extra energy go. Heat! This is why a pump will burn out if loaded too lightly or heavily.
I am trying to calculate cost saving / ROI for various replacement pumps and want to model actual consumption.
Regarding sizing the pressure gauge at the filter shows 15 psi (35 ft of head), so if I add suction side head of 8 ft I am at 43 ft of head - does that make sense ? The pipes around the filter and in the ground are all 1 1/2 inch PVC so I should not go higher that 44GPM which is fine for the 8-10 hour turnover.
Yes but remember without a suction measurement, this is only approximate but probably within +- 3 ft. Also, if you have pipes plumbed in parallel, they can each handle 44 GPM. So depending on design, the flow could be more.
Pump options are (some might be a little crazy)
- a regular EE pump, .5 HP such as the Northstar NS4005 although flow at 40 ft of head would be a tad too high for the plumbing
Ah but this is the funny thing about hydraulics. If you reduce the pump HP, the head the pump sees is reduced as well. Here is a good rule of thumb:
RPM ~ GPM
Head ~ GPM^2
BHP ~ GPM^3
Head ~ BHP^2/3
~ means proportional
So
New head = Old Head * (New BHP / Old BHP) ^ 2/3
- a two-speed pump such as the smaller Pentair WhisperFlo WFDS-3
very tempting - a 115V - means I don't have to run new cables.
- PMSM based pumps such as Pentair IntelliFlo 100, 160 or the big one. They are expensive but might work out IF the energy savings are close to what Pentair claims. Do you have any idea how to estimate this ?
You would need to get the pump curves and amp usage for each of the RPM settings. Perhaps on their web site.
Patrick
