Re: Liner Issue - Extra floppy on the toppy
Hi, That happens a lot with beaded liners(it appears you have a j-hook liner of sorts). In the hot Arizona sun where I installed pools it happened a lot. Since that was unacceptable for a pro I always carried extra coping. It was always a last minute decision, after having filled the bottom of the pool with water, do I use the bead or pull the liner over the wall and use coping? Most of the time it was coping but that always left the liner tight and looking good.
You could probably do the same, pull the liner up and over the wall and use coping. You could also drain the pool, let the liner sit and shrink for a couple of days and refill. You could also drain and hook a shop vac up to it, that might flatten it out, at least you would know before you filled it again. Removing some of the cove, or base, is also an option, but one I would use as a last resort, it's so much extra work.
Hope that helps, Dennis
