Results 11 to 13 of 13
Thread: Hayward Super Pump not priming
    mas985's Avatar
    Pleasanton, CA
    Default Re: Hayward Super Pump not priming
    So you already replaced the seal?
    If so, then yes, the large gasket might be the motor plate gasket and that can leak in the same location as the shaft seal.
    Mark
    fog80 is offline Registered+ Thread Analyst fog80 0
    Columbia, Maryland, USA.
    Update: found another crack in the plastic housing outside of the "pot". Sealed this up with epoxy and everything started working great.
    3 days later the leak is back, albeit smaller than the original leak.
    Looks like I'm going to have to get a new plastic housing while this one is still working.
    Moral of the story: if you have a leak under the pump, always check housing for cracks before doing something drastic like replacing shaft seals and gaskets.
    20,000 gal IG plaster, Hayward Super Pump, EC65 DE filter.
    Replaced the housing with one bought off amazon for about $150. So far so good.
  1. Hayward super pump 3/4 ?s
    By Messina1974 in forum Pool Equipment & Operations
    Last Post: 06-27-2013, 10:34 AM
  2. hayward super pump
    By lnjwink in forum Pool Equipment & Operations
    Last Post: 06-11-2012, 03:06 PM
  3. Hayward Super Pump is Super Noisy
    By moneypitpool in forum In-Ground Pool Construction and Repair
    Last Post: 07-25-2011, 10:16 AM
  4. Hayward Super Pump - Super Hot and Shutting Off
    By CapitalBoo in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 09:32 AM
  5. Hayward Super Pump Really Hot...HELP?
    By calamtykel in forum Pool Equipment & Operations
    Last Post: 06-14-2009, 04:30 PM
