Thread: Pool Heater size
    Jun 2014
    New York
    Default Pool Heater size
    Hello all:
    I had a 400,000 BTU Raypack 2100 heater which died last month after 12 years. I had a new heater installed and asked for another 400,000 BTU unit and thought that was what I was getting but the bill stated it is a 325,000 BTU unit. The tech said they always downsize new units because the new unit are more efficient and they draw more gas at start up and this can create an issue at startup with the unit cycling on and off. He said if I wanted the larger unit I might need to upgrade the line at the meter.
    Doesn't make much sense to me that a new heater would draw more gas then an older one but I'm out of my realm with this.
    Any information appreciated.
    Default Re: Pool Heater size
    He's correct that newer heaters are often significantly more efficient. That old Raypak may have been 60% efficient; I believe the current Hayward Universal heater runs about 83% efficient.
    I'm not sure about the other. If he meant that over-sized heaters can cycle on and off too much, he's potentially correct. But if you understood him correctly, than some of what he's saying is just gobbledygook, probably due to ignorance rather than maliciousness. Over the years, while waiting at the pool wholesalers, I've heard pool guys express truly bizarre misunderstandings of how things work.
  1. Estimating size of pool
    By zacht in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-19-2012, 04:51 PM
  2. Pool Size
    By tropic in forum Pool Equipment & Operations
    Last Post: 05-01-2010, 01:12 AM
  3. Size of Heater
    By jklym in forum Pool Equipment & Operations
    Last Post: 09-11-2006, 02:11 PM
  4. How to calculate the size of my pool
    By Sunny32504 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2006, 11:16 PM
