Results 1 to 9 of 9
Thread: Getting started with an Intex pool
    Default Re: Getting started
    . . . membership upgraded.
    + If you haven't already opened the box, and can still return the pool, you may want this one instead:
    12 x 30 Intex for $120 @ Amazon
    The frame pools are MUCH more durable than the doughnuts, which often succumb to cat or squirrel claws, or bird beaks.
    + Follow the SSR, like WaterMom suggested.
    Jun 2014
    Wisconsin
    Opened the pool and set it up today since we are no longer planning to leave at all next week. I am confused about what I am supposed to be doing though. So this is what we did so far...
    In the 1000 gallon 10' x 30" pool we filled with water. When it was about half way full we added 1/2 cup bleach. Tonight, we added 1/8 cup of the kem-tech dichlor, and 1/8 cup of polyquat. I did not check any levels of anything so far, we were going to see where we are at in the morning.
    Does this sound right? I got confused as to what the dosage should be since we already have the dichlor on hand. I wasn't sure how to do the simple start up while also trying to build the cya.
    Also, I just realized it said to put in the borax with the dichlor, which we forgot about.
    10 x 30 Intex Easy Set
    Jun 2014
    Wisconsin
    Also, I ordered an upgraded filter. I am wondering if I need more than one, or if I can just pop it out to clean it and pop it back in. How long should the pump be running each day, or is it best to just let it run all the time?
    BigDave's Avatar
    Quote Originally Posted by Mom2ari View Post
    ... In the 1000 gallon 10' x 30" pool we filled with water. When it was about half way full we added 1/2 cup bleach. Tonight, we added 1/8 cup of the kem-tech dichlor, and 1/8 cup of polyquat. Good! I did not check any levels of anything so far, we were going to see where we are at in the morning. Don't measure CYA now - there's too little to measure - How are your numbers?
    Does this sound right? Yes! I got confused as to what the dosage should be since we already have the dichlor on hand. 1/8 Cup sounds pretty good. I wasn't sure how to do the simple start up while also trying to build the cya. Follow the Intex Pool Care Plan section of the Super Simple Recipe.
    Also, I just realized it said to put in the borax with the dichlor, which we forgot about. The Borax is there to counter the acidity of the dichlor, if the pH is above 7.5, skip a dose.
    Don't even bother to measure CYA until you've used a pound of dichlor. After a pound, there will be about 60ppm CYA. Measure it to verify then start chlorinating with bleach.
