Thread: 8.25% bleach
    Sep 2011
    Central NJ
    Default 8.25% bleach
    8.25% bleach seems to be the new standard 'concentrated' strength. I tend to use pool calculator to work out my levels but it doesn't give 8.25 as an option down in the "Effect of adding chemicals" section. Could anybody tell me what adding 128 ounces of 8.25% bleach to a 10,000 gallon pool would give as PPM?
    Thanks!
    24' Round 52" (44"/12450gal) Deep Namco Morada - ClearWater 22" Sand Filter - 1.5HP (SPL) Speck Pump - Taylor K-2006C Test Kit
    May 2014
    Plano, TX
    Default Re: 8.25% bleach
    According to this
    http://pool9.net/bleach-calc/
    1 gallon of 8.25% bleach in 10,000 gallons adds 8.2 ppm chlorine.
    The "More Calcs" tab in the upper left corner lets you access more calculators and settings (imperial vs. metric).
    Sep 2011
    Central NJ
    Thanks! Guess that app doesn't like running in windows 8 much, even in compatibility mode.
    No, that is one of the problems we have found with that calc. It doesn't like Win8.
    Sep 2011
    Central NJ
    Ok, I had to setup a Windows XP virtual machine to check out the app.
    The calculations between this app and www.poolcalculator.com dont really jive. I wonder which one is more accurate. The bleachcalc seems to be purely math... 1gal pool, 1 gal 5.25% bleach = 52500 ppm.. making it 10 gal pool just moves the decimal point. The poolcalculator says 54007 for the same values. I know its not enough to care about especially when you move the size of the pool up to 10000 gallons but I wonder where the poolcalculator is coming up with the difference.
    Here is the formula I use for manually calculating chlorine. 1,000,000/10,000 x .95 x 0.0825 = 7.8
    One million divided by the total gallons of water in pool, then multiplied by .95 (121 oz of chlorine is converted to a decimal) x 0.0825 (% of chlorine in jug).
    121 oz is the amount of bleach in the jugs of bleach I use.
    Hope this helps you.
    Largo, Florida
    The pool calculator website is client side scripting so you can see the calculation by viewing the source. Here's what it's doing:
    parseFloat(document.F.FCto.value)-
    parseFloat(document.F.FCfrom.value)) *
    GetGallons() / 482.202 * 6 / parseFloat(document.F.FCpcnt.value);
    document.F.FC1oz.value=PutVolume(temp);
    Which is basically Target increase*water volume /482.202*6/LC strength
    Perhaps the difference is in order of operations or that 482.202 constant. I'm not intimate enough with the formula to know what that is for. I wonder why they didn't use 2,893.212 for the constant.
  1. Storing bleach outside; decomposition of bleach
    By tmess13 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-03-2013, 08:24 PM
