Thread: 8.25% bleach
    Default Re: 8.25% bleach
    Here is the formula I use for manually calculating chlorine. 1,000,000/10,000 x .95 x 0.0825 = 7.8
    One million divided by the total gallons of water in pool, then multiplied by .95 (121 oz of chlorine is converted to a decimal) x 0.0825 (% of chlorine in jug).
    121 oz is the amount of bleach in the jugs of bleach I use.
    Hope this helps you.
    Largo, Florida
    The pool calculator website is client side scripting so you can see the calculation by viewing the source. Here's what it's doing:
    parseFloat(document.F.FCto.value)-
    parseFloat(document.F.FCfrom.value)) *
    GetGallons() / 482.202 * 6 / parseFloat(document.F.FCpcnt.value);
    document.F.FC1oz.value=PutVolume(temp);
    Which is basically Target increase*water volume /482.202*6/LC strength
    Perhaps the difference is in order of operations or that 482.202 constant. I'm not intimate enough with the formula to know what that is for. I wonder why they didn't use 2,893.212 for the constant.
