Hi, DC,
If you'll bring your pH down into the 7.2 - 7.6 range, you'll be in pretty good shape. Download the bleachcalc if you haven't already, and use the section on pH to lower it with muriatic acid. Alk will come down some when the pH lowers. It would be a good idea to lower the pH sooner rather than later.
Calcium is fine.....you really don't need it, anyway.
If you consume quite a bit of Chlorine, you might consider taking your CYA up to 30-40. I'd leave it alone if your happy with your Cl usage, tho.
Very thorough post with all your pool parameters and test results...Thanks! Happy swimming!![]()
