Re: 1st Pool Just Set Up - Am I on the Right Track
OK - perfect. So, if I add it at night, do I need to run the filter all night or, assuming we don't swim that day, can I add chlorine at night but shut the filter off for the night as well. I guess the better question is - how long does the filter need to run after adding chlorine. Thanks again!
22' x 52" Intex AG pool
Run the pump for a couple hours after adding chemicals.
