Thread: Leak in main drain located in vermiculite outside pool wall
    Jun 2014
    South Dakota
    Default Leak in main drain located in vermiculite outside pool wall
    I've verified a leak in the main drain line of my inground pool. Dug down to the line only to discover that there's still about 6" of line outside the pool wall covered in vermiculite that I can't access. I can see water flowing out here when my line is not plugged. What's the best way (very right space-concrete saw not an option)to remove the vermiculite so that I can find the leak in the line?
    Default Re: Leak in main drain located in vermiculite outside pool wall
    If it is just vermiculite, I'd just use a big screwdriver or something to chisel it out.
    But something about your description doesn't make sense: vermiculite + cement used under liner pools is pretty soft and weak. The fact that you are talking about a concrete saw makes me wonder what you really have.
  1. Main Drain Clogged on Old Pool
    By sharpaaa in forum In-Ground Pool Construction and Repair
    Last Post: 07-01-2013, 03:05 AM
  2. Inground Pool Main Drain Plumbing
    By byron366 in forum In-Ground Pool Construction and Repair
    Last Post: 05-28-2011, 10:35 PM
  3. Plugging main pool drain.
    By grpargeter in forum Pool Equipment & Operations
    Last Post: 06-07-2010, 08:55 PM
  4. Cemented Main Drain and wall grate questions
    By RobDHW in forum Pool Equipment & Operations
    Last Post: 05-27-2010, 12:32 PM
  5. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
