First you should NEVER add acid to the skimmer! It can cause damage.
If you want to lower your ALK you need to add enough acid to get your pH down to 7.0 (but not any lower with a vinyl pool!) and then airate to lower the TA. As you airate your pH will go up and your TA down.
Hope this helps
