Thread: Too Much Chlorine For Dogs?
    Mar 2014
    NC
    Default Too Much Chlorine For Dogs?
    Is there an upper limit for chlorine that's too much for dogs? We have a new puppy (12 weeks) that, for the first time for a dog of ours, we have decided to teach to swim and behave in the pool. I am currently keeping the FC around 8-10 (CYA 60-70). Certainly, when I was fighting algae last month and FC was near 20, I would say levels like that may be a problem, but is it really?
    Any resource for toxicity levels for FC in pools for pets?
    Thanks!
    25,750 ga 18x36 Rectangle IG Vinyl liner; Hayward 250 sand filter; 1.5 hp pump. PF=4.4
    Default Re: Too Much Chlorine For Dogs?
    Unless your dog is using the pool as a water bowl drinking a lot from it, then it should be OK. Worse than chlorine would be if you were using 50 ppm Borates and the dog was drinking a lot. The risk is still low, but it gets closer to where it could be a problem.
    Mar 2014
    NC
    Thanks.
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    In the summer my dogs refuse to drink from anything but the pool. They are old and healthy.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
