Is it typical for the little testing dipper that comes with the R-0870 reagent to turn a rusty brown color with use? I'm guessing it's oxidation? Will that effect the test?
Thanks,
Splash
Thanks,
Splash
19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
I have had my current kit for a couple of years. My dipper is plastic and I'm not seeing what you are seeing. But, I wouldn't think it would affect the validity of the test, though.
Well then Taylor either changed the plastic they're using or I've got some kind of contamination. I'll take a picture when I get home.
Splash
If this is a new kit, you need to return it.
If it's an old kit, you need to replace the dipper (and powder?)
I emailed in photo. It's turned into a oily black. I think it may be the dipper is coming in contact with the little foam pad packed underneath and causing some type of reaction.
