Results 1 to 3 of 3
Thread: cloudy water
    Question cloudy water
    Hi ,
    this is driving me crazy!!! I have a 30 ft round above ground vinyle pool 28,000 gal
    sand filter running 24/7
    PH 6.5
    cl 5.0
    br 11
    alka 110
    stab 150
    harness have above 4000 kept adding drops but no change stopped at 80 drops
    have HTH
    HELP !!!!!
    IL.
    Default Re: cloudy water
    WoW! Stabilizer of 150 is REALLY high! You have two choices. 1- do a partial drain and lower it. Actually, it would take a couple of partial drains to get it down to a manageable level. We like a stabilizer level of 30-50, but can live with it some higher. 2- Keep your level as it is but runner higher than normal chlorine levels. See the chart at the following link for more about that.
    A few other comments. Ph is way too low. That is your most immediate problem. PH below 7.0 is acidic and can damage your pool. Add a box of Borax to your skimmer while the pump is running. Wait 3-4 hours to let it circulate, then retest and redose til you get it above 7.0. Then, go with smaller doses til you get it to 7.4-7.6.
    You don't have chlorine and bromine in your pool. Unless you have added bromine, you don't have any. In a vinyl pool, calcium hardness isn't relevant as long as it isn't above 500.
    http://www.poolforum.com/pf2/showthread.php?t=365
    Any more questions or help needed - ask away.
    EDIT: The more I think about it, with a 28,000 gallon pool, you could probably get away with adding 2 boxes initially.
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
