Results 1 to 9 of 9
Thread: Problems with Hayward t-15 salt cell
    Jun 2014
    Default Problems with Hayward t-15 salt cell
    Just some info. I have the Hayward gold T-15 salt cell. It is about 8 years old and I started having problems with it reading "hot" and not generating.
    Default Re: Problems with Hayward t-15 salt cell
    . . . membership updated.
    If your AquaRite is 3+ years old, those results ('hot' + no chlorine in spite of adequate salt levels) most often mean a dead cell. Even though this is a fairly common event, Hayward apparently does not recognize it as a common 'trouble' condition.
    You can call them, if you like. If you choose to do so, run through the diagnostic display first:
    Diagnostic Displays
    Sequential pushes of the small "diagnostic" button next to the LCD display will cause
    the Aqua Rite to display the following information:
    1. Pool temperature (xx degrees Fahrenheit or Celsius)
    2. Cell voltage (xx.x volts)
    3. Cell current (x.xx amps)
    4. Desired Output % ("0P" -- "100P" depending on knob position or input from remote
    pool automation controller)
    5. Instant salinity ( -xxxx ppm or -x.xx grams/Liter)
    6. Product name sent to the pool automation control display ("AL-0" which signifies
    "Aqua Rite")
    7. Software revision level (r1.xx)
    8. Chlorinator cell type (t-3, t-5, t-9, t-15)
    On the 9th push of the button the display will revert back to the default salt display.
    Also, if the button is not pushed for 30 seconds, the display will revert back to the
    standard salt display.
    You can get copies of the manuals on the Hayward AquaRite page.
    If you decide to just go ahead and replace the cell, definitely run the diagnostics, to make sure you're getting normal power to the cell AND, order a larger cell. Cell life expectancy is directly related to cell "ON" time. As a result a larger cell -- which will run less -- will last much longer.
    Hayward AquaRite T-40 cell @ Amazon
    Jun 2014
    What I did was cut the red and blue wires going to the temp sensor. I added a 10K ohm adjustable resistor and set it to 84 degrees (8.4 K ohms). It seems to be working again!
    What made you think the temp sensor had failed? (Not challenging, just asking.)
    Jun 2014
    The gold line controller was reading "hot". I turned it off and turned it on. It initially would register salt content (3300), then the generating light would start blinking and read hot, meaning not generating. I turned the controller off, set a bag of ice on the cell and let is stay for a few hours. When the ice melted, I turned the unit on and it read the temp at 174 degrees for a few seconds, then went to "hot". I tried to recalibrate. The controller went through it's calibration sequence and then read "hot" again and stopped generating. I opened the cell, cut the temp sensor wires and checked continuity on the switch. Continuity was bouncing everywhere. Figured it was shot. It should read somewhere around 8k-10k with the temp being in the mid to upper 80s. I will use my makeshift temp sensor for a while to make sure it is working, then probably order a Jandy replacement switch and install it. So far, so good. The water tests turned out exactly what the controller is reading.
    Very helpful. Thanks.
    I've been having a similar problem with the temp sensor in my Turbo Cell T-Cell-15 http://www.titaniumcells.com/t-cell-15.html aftermarket cell, for a while. It worked well for year or so then started to shut down due to the AquaRite controller showing "HOT." Selecting the temp readout, showed in excess of 100 degrees F with an actual water temperature in the range of 75 to 80 or so.
    I put my old original equipment cell back on temporarily just to confirm it was the cell and not the controller. Sure enough, the old cell presents the correct temperature to the controller. In addition I noticed that when I unplug the cell from the controller I get a temperature reading of 77 degrees. Pretty close to where my water temperature stays most of the season and well within the range acceptable to the controller.
    This knowledge led me to a solution. If you open up the controller and remove the circuit board you will see a very thin, almost hairline thick trace, going to one of the pins of the cell connector. This connects to the temperature sensor in the cell. I took an exacto knife and sliced through that trace. Put everything back together and what do you know, problem solved. The temperature now always reads 77 degrees and cell function is back to normal!
    I suspect the cell uses a thermistor as the temperature sensor and that salt water gets inside the plastic probe cover. This radically alters the resistance seen by the controller and you get these bad readings. My cell is still under warranty (3 years), but I can't afford to spare the time required to get a replacement from the manufacturer. I mean it's summer, the pool needs chlorine. Maybe this winter.
    Hope this helps someone.
    Greg
    Thanks, Greg.
    Jun 2014
    Greg, that is the exact reason I installed a variable resistor. I can change the water temp to match what my in water thermometer is reading.
  1. New T-CELL-15 reading lower salt than 7 year old cell
    By sharknj in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-01-2013, 10:00 AM
  2. Salt cell died?
    By Fornman in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-24-2013, 11:48 PM
  3. pentair salt cell
    By bradc344 in forum Pool Equipment & Operations
    Last Post: 04-30-2012, 10:57 AM
  4. Salt Cell Replacement
    By JimSentry in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:01 PM
