Results 1 to 8 of 8
Thread: First post current numbers
    Default Re: First post current numbers
    Sounds good.
    Taylor K2000 or K2006?
    May 2014
    Baton Rouge, LA
    I ordered the K-2006. It has the wheel thing. Did I order the wrong one? I am so numbers challenged anyway and to have to try and fix something using numbers is very difficult. I hope I never lose my notebook full of pool info.
    Thanks so much
    Lisa
    K2006 is the right one. Ignore the book/wheel thing. The kit is great. Those other two things are not so good.
  1. Going to Switch to BBB method.. just posting my current numbers for recommendation
    By jdees in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-31-2011, 07:49 PM
  2. Stray Current??
    By adesalvo in forum Pool Equipment & Operations
    Last Post: 08-13-2007, 10:53 AM
  3. Replacing current pump with two speed
    By DavidP77 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-03-2007, 10:11 AM
  4. My first post and first test numbers
    By sharknj in forum DPD-FAS based testing
    Last Post: 06-04-2006, 04:26 PM
  5. told to post numbers and help will come!!
    By timmie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2006, 09:03 PM
