Results 1 to 10 of 11
Thread: Pool Pilot Questions
    Default Re: Pool Pilot Questions
    Is your heat pump salt water compatible? It looks like it should be but I found no such statement on the website.
    Yes. It has a titanium heat exchanger with a lifetime guarantee against corrosion. I've had mine since 2003. http://www.heatsiphon.com/2006websit...4nolimits.html
    Quote Originally Posted by JimK View Post
    A bit of info for you:
    My coworker said they've replaced the cell once in the past 10 years (31k gal IG vinyl pool). My appologies, but I didn't think to ask her about runtime. She did say they had to replace the display board a couple weeks ago.
    I'd have to look at my records, but it seems I'm running mine a little higher this season. It could be my cell is showing it's age and may have to be replaced this season. I'll get more details for you this evening.
    Thanks. I appreciate the info.
    18x36 Vinyl Liner Inground 25,000 gals, Hayward 1.5HP Super Pump, Hayward Pro-Grid DE3620 DE Filter, Heat Siphon SX5.0HP Heat Pump, Pool Pilot Digital - SC-52 SWCG, PS233 Test Kit
    Virginia
    More Aqua Rite info;
    Looking at my past records I run the pump about 12-14hrs a day with the SWCG typically set to 50-60%. So far thus season the pump is running 12hrs a day with the SWCG set to 70-75%.
    I also found in 2009 the main board was replaced (was still under pro rated warranty).
    So since having the pool and Aqua Rite installed in March 2004, the cell has been replaced once and the main board has been replaced once.
    I hope this info helps.
