Should I convert?
I've been following the BBB and other methods recommended on this forum. It's been awesome to know exactly what to do.
I've discontinued using tri-chlor for chlorination since at the end of last summer my CYA was over 100! I've switched to using generic liquid bleach from the grocery store. I'm buying 1 1/2 gallon jugs at $3.30 each. Now that it's getting hot I'm having to use 1-2 jugs every night! That's $3.30-$6.60 a day. Seems expensive and I'm having to check levels 2x a day with my Taylor kit. I'm paranoid about the levels dropping below 5 because of previous mustard algae disasters. Here's a typical reading in my 36k gallon vinyl pool:
FC: 8
PH: 7.3
CYA: 55
The appeal of a SWCG to me is lower cost and less maintenance. I know i'll still have to test a lot especially at first. I'm wondering if anyone has a cost for usage including the unit, salt purchased, etc. And do you recommend pursuing this over manual dosing every 12 hours? Is it worth it?
Also, my local pool store has quoted me $3k to install a Hayward Aquarite system. I'm very skeptical of any pool store after reading stories here and think this is a ripoff. I've done my own cost analysis and think I could buy the unit for around $1000 and the salt needed for around $170. If I installed it myself or had a plumber help could the cost be around 1200? Am I missing something?
Do you guys recommend this as a DIY project? I am familiar with basic wiring and electrical setup. I realize I would not have support if it did it myself and that may be an issue if these are prone to have problems. I'm looking for any advice you might have.
21x45 rectangle 28K* gal IG vinyl pool; Chorine feeder; Hayward Pro Series sand filter; Hayward 1.5hp 1 speed pump; 8 hrs; ; 6 drops ; well; summer: none; winter: none; iPad; PF:4.2
