Thread: salt too low on salt system
    Jun 2014
    california
    Default salt too low on salt system
    Everything was working well...chemistry good. One day low salt came on. I had added about 2 inches of water to my 15 ft. round intex pool previously several days before light came on. I added 6 lbs salt but light stays on, Ended up putting a total of 18 lbs all together and the light remains on. I run the pump 3 hrs a day, chem strip shows very little clorine. This is my 2nd years with this system and I cleaned the electrodes as recommended after last season. Any ideas on this problem? thanks, jim
    Jun 2014
    california
    Default Re: salt to low on salt system
    its model # is cs711. I had the water tested today. salt was way high at 5100. I took out half the water and am now refilling it. I also cleaned the eletrodes but they didn't look to bad. Hopefully, this will take care of the problem.
    The manual for a "CS7110" Intex SWCG is here:
    http://slink.intexdevelopment.com/b2...R0_1406_EN.pdf
    I don't think there is a CS711.
    Let me know of the lower salt level fixes things, however the Intex SWCG have only a 1 year warranty -- and if you use BOOST mode (AKA the 'kill my SWCG unit quickly' mode!) much you'll be lucky if it lasts 1 month past warranty.
    Jun 2014
    california
    Default Re: salt too low on salt system
    that number is 7111. Are there better units I may want to look into?
    May 2014
    Plano, TX
    There are definitely better better SWCGs than Intex, and they cost significantly more. Adapting a NON-Intex SWCG to an Intex system can be done, but it requires some adapters and ingenuity. If I was replacing an Intex SWCG, I'd probably get the biggest Intex model available and use it ONLY for normal operation. I'd shock with Walmart generic bleach. If I was replacing the WHOLE circulation system AND was confident that I'd have a pool for 5 years, I'd look at Penair and Hayward systems if I was having a contractor install it and a Hayward if I were installing.
    Pappy
    What he said . . .
    "Penair" = Pentair. Pentair pumps and filters are generally good. Their salt systems? Not so much.
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Nature Two Pool System Versus Salt System
    By billie in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-03-2012, 01:27 PM
  3. New Salt System and Low CYA
    By AndreaA in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-26-2011, 02:25 PM
  4. Salt water magic and Intex salt water/copper ionization system
    By enchantedmountain in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-10-2011, 05:37 PM
