Re: Hello
Oh wow your awesome for sending me this information. So I assume with what you said you agree that it is mustard algae based on the color and the dissipation factor?
Right now I am using Aquachek Pool & Spa Test Strips: Free Chlorine. It does check for Free Chlorine, pH, Total Alkalinity, and Cyanuric Acid (stabilizer). Today in NJ we had a hot day so my chlorine went from perfect to fail, as well as the pH. I guess that could have added to the mustard algae issue. I would have thought with a DE filter it would pick it up? Although the skimmer is at the top and I have nothing at the bottom of the pool. I did point the jet down in hopes of getting the algae to the surface and for the DE to pick it up.
Also thanks for correcting me on the shock and chlorine, I mis-spoke but meant what you said. I think I might go that route, shock, if you can confirm that what I describe is mustard algae.
Thank you again!!
10k gal AG pool with 1.5HP pump & DE filter
