Thread: Consequences of filling in the drain in the deep end
    Jun 2014
    Arkansas
    Default Consequences of filling in the drain in the deep end
    we are replacing the liner in our in ground pool. I was wanting to know if it is ok to fill in the drain in the deep end and cap off the line at the pump. Will there be in negative effects. we have a automatic pool vacuum.
    Default Re: Consequences of filling in the drain in the deep end
    1. Somewhat poorer circulation. If your pool is prone to mustard algae, this could make it worse.
    2. Many automatic vacuums do not pick up fine dust, so you may have to manually vacuum that.
    3. You won't be able to drain your pool below the skimmer throat, without using a separate pump.
    . . . membership upgraded.
    Jun 2014
    Arkansas
    Thanks. I think we are going to try and keep the drain. Hopefully no problems.
    We hope so, too.
  1. To drain or not to drain pool with high CYA?
    By stevemac213 in forum Pool Chemicals & Pool Water Problems
    Last Post: 10-14-2013, 05:49 PM
  2. Replies: 2
    Last Post: 05-09-2009, 12:04 PM
  3. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
  4. How Deep 5.5, 6, or 6.5
    By JimCrackorn in forum In-Ground Pool Construction and Repair
    Last Post: 07-26-2006, 10:08 PM
  5. high alk consequences?
    By dhale63 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-17-2006, 03:54 PM
