Re: Mustard Algae and Sodium Bromide (Long)
The sodium bromide creates a bromide bank in the pool that you need to activate by shocking with chlorine after adding it. You will then temporarily have a bromine pool. If I am not mistaken bromamines will form and the algae will consume them and be killed. If you just add the bromine and don't shock the pool it really doesn't work. Keep shocking and it should take care of the mustard. The bromine can create a large chorine demand for a while. that is normal. Just keep getting the chlorine in there at shock levels until the pool clears and the FC is holding. CYA will do you no good as long as the pool has active bromine in it since bromine isn't stabilized by CYA.
