Results 1 to 10 of 18
Thread: HELP - Saltwater System Inital Setup - Intex 54601EG
    QiingGuy is offline Registered+ Thread Analyst QiingGuy 0
    Jun 2014
    Las Vegas
    Default HELP - Saltwater System Inital Setup - Intex 54601EG
    I bought a used system and the guy didn't have the manual. I've found bits and pieces on the Internet but what I cannot find is the following, hopefully someone can help me out. Current status 16" x 48" Intex Ultra pool, I put 120 lbs of pool salt in the pool and have let the pump run overnight (still running).
    1) When do I turn on the Saltwater system and how long do I run it for first time?
    2) How long do I run it daily after the initial run?
    3) I assume the salt water system and pump need to run at the same time, how do I synchronize the two?
    Thanks in advance, not having a manual is driving me nutz!
    UPDATE: Spoke with Intex and I hate to say this they were no help other than telling me I need to run the system 3 to 4 hours a day. The person I spoke to had such a heavy accent that this is all I could make out from our conversation so my questions above still apply with the exception of how long to run daily after the initial run.
    Default Re: HELP - Saltwater System Inital Setup - Intex 54601EG
    I can't answer most of those questions but will tell you that you want to get your water balanced before you turn on the unit. Do you have a drops-based test kit? Can you post current readings?
    Also, disconnect the copper electrode that is on the unit. Contrary to popular belief, it is not chlorine that stains pools and turns blonde hair green, it is copper!
    Jun 2014
    Las Vegas
    @watermom I don't have drops but I have strips, will that work?
    Jun 2014
    Las Vegas
    Here are the strip results:
    TH - 1000
    FC - 0/0
    Ph - 6.8
    TA - 120
    CYA - 0
    Well, we actually call them 'guess strips' around here......
    The test kit that we think is by far the best is the Taylor K2006 or 2006C (better buy). Not available locally but you can get it through this link that takes you to Amazon: http://pool9.net/tk/
    But, in the meantime, go to Walmart and see if they have the HTH 6-Way drops-based kit (no test strips!) and get that. If they don't, get an OTO/Phenol Red kit (yellow and red drops) instead. Use it to test and then post your numbers. Also while you are at WallyWorld, get several jugs of their generic 8.25% bleach and a 2 or 3 boxes of 20 Mule Team Borax (laundry aisle).
    Then, test and repost the numbers. (Do this asap. Your pH appears to be critically low and can damage your pool and equipment! Any reading below 7.0 is acidic. So...... get off to Walmart!)
    Jun 2014
    Las Vegas
    Thanks! Wife's on her way to Wally World!
    Jun 2014
    Las Vegas
    Here are the chlorine and pH numbers:
    Cholrine - Totaly Clear so I guess that's a zero.
    Ph - 7.8
    Still trying to figure out how to conduct the other tests.
    Jun 2014
    Las Vegas
    Here's latest update on tests. Please note my CYA question:
    TH - 340 (wasn't red, more like purple prior to adding hardness titrant)
    Ph - 7.5 - 7.8
    TA - 150
    CYA - Not sure I'm reading this test right. It's asking me to add 7 ml of the cyanuric acid reagent to 7ml pool water. 7 ml of acid reagent is 1/3 of the total amount that came with my kit)
    Since this is a new fill, you won't have any CYA in there yet unless you have used some trichlor pucks, dichlor shock or have added any CYA separately. I assume you have used none of those?
    What exactly have you added to the pool by the way -- ingredients, please? When did you fill it?
    (Do you see now why we call them 'guess-strips'? )
    Jun 2014
    Las Vegas
    Partially filled 5 days ago, finished filling last night. Added about 3 to 4 cups of bleach since initial fill and 120 lbs of salt, that's it.
    Just checked my salt level (using strip LOL) and I'm sitting at 2,860.
