Results 1 to 10 of 16
Thread: cloudy darkish water
    May 2011
    centralcalifornia
    Default Re: cloudy darkish water
    Ok. FC is 7. CC is 0. TA IS 80, CH is 350. CYA is 55. Ph is between 7.6 and 7.8
    I did throw in some algaecide last night and now water is milky white and can see the bottom of deep side, thiugh not clearly. The stuff is called skill-it from biodex. Before I threw the algaecide s the water was still green despite running filter 24/7. I never tried the cellulose fiber and will be returning it.
    Been running filter and threw in some DE to where pump psi went from 7.5 at clean back wash to now 8.5 psi. I'm going to the store right now to get the stuff to do the metal test.
    May 2011
    centralcalifornia
    Chemgeek, I will follow your instructions once I see what's going to be the conclusion with this algacide. I threw in the algacide last night and read your post this morning. Oh, the water color now is like a pale white blue.
