Thread: Liner repair
    Jun 2014
    NJ
    Default Liner repair
    Opened my pool and found my liner floating. I pumped the water from unground and then found water level well below what it was hen I closed the pool last year. Need Help!!!!!!!!!!!!
    Default Re: Liner repair
    You can't assume that the missing water leaked under the liner: that's possible, but there are other possible explanations too.
    1. You probably need to determine if the pool is still leaking. Start a bucket test (http://pool9.net/bucket-leak/ .
    2. If it's NOT leaking, raise the level 6" and see if it leaks then: it may have gone down to the level of the leak -- if so, you'll at least have a much better idea of where to look.
    3. Fix the leak.
    4. Look for wrinkles BEFORE you fill back up. If you're going to need to put vacuum on the liner, drain it, & fix the wrinkles -- do it BEFORE you refill the pool.
    . . . membership upgraded.
  1. Replace or repair liner?
    By TimWillin2 in forum Above-Ground Pool Construction & Repair
    Last Post: 10-29-2012, 08:57 AM
  2. Liner has came out of track. Repair ideas??
    By johndeer in forum In-Ground Pool Construction and Repair
    Last Post: 05-24-2012, 12:54 PM
  3. Replace or repair my vinyl liner?
    By famdog in forum In-Ground Pool Construction and Repair
    Last Post: 04-26-2007, 08:02 PM
  4. Liner repair
    By goldstar38133 in forum In-Ground Pool Construction and Repair
    Last Post: 05-05-2006, 10:53 AM
