Hi, John, and welcome to the Pool Forum!
First thing is to ditch the 'guess-strips.' They are not reliable. The test kit that we think is by far the best is the Taylor K2006 or 2006C (better buy). Not available locally but you can get it through this link that takes you to Amazon: http://pool9.net/tk/
But, in the meantime, go to Walmart and see if they have the HTH 6-Way drops-based kit (no test strips!) and get that. If they don't, get an OTO/Phenol Red kit (yellow and red drops) instead. Use it to test and then post your numbers. Also while you are at WallyWorld, get several jugs of their generic 8.25% bleach and a couple of boxes of 20 Mule Team Borax (laundry aisle).
A couple of questions for you:
-- Is this a freshly filled new pool?
-- Exactly what all have you added to the pool --- meaning ingredients and not just 'shock.'
Repost with requested info and then someone here can try and help you.
Search here:> http://pool9.net/search/ (It is much better than the search feature that is built in to the forum software. This link will search all of the forum plus our sister website www.poolsolutions.com
(Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
