Results 1 to 10 of 11
Thread: CYA Test
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    Default CYA Test
    I just want to verify that when doing the CYA test that your looking for the black dot to entirely disappear.
    I added 3lbs of stablizer to my pool(15k gallons)and my CYA reading is still at 0(or below 30ppm). I had also been using trichlor tabs up until 3 days ago. So far my TC level has remained well above 12ppm and I havent added any bleach for the last 3 days trying to get it down to 3ppm.
    John
    prh129 is offline Lifetime Member Widget Weaver prh129 0
    Rehoboth, MA
    Default Re: CYA Test
    Quote Originally Posted by jrv331
    Yes, that's correct. Keep in mind that CYA dissolves very slowly so it will take 5-7 days before you get an accurate measurement of your CYA level after you add the CYA.
    Peter
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    I know this isn't my thread, but I've got a quick question about the CYA test too...
    When I do my testing I generally sit at my kitchen table. I do my CYA test standing at the window (my kitchen window faces East, so I get morning sun). This morning my results standing at the window were 50. Just for kicks I stepped outside on my porch in the direct sunlight to see what I got there. Out on the porch I was able to add more of the testing mixture before the last hint of the dot completely disappeared and got a reading of 40. So, which is the most accurate reading?
    Sherra
    Kershaw County South Carolina
    18x34 IG 2' radius rectangle vinyl liner (approx 27,500 gal) 1 1/2" pipes installed March 2006
    (previous AG pool owner)
    Rehoboth, MA
    I can't recall what the directions in the PS234 kit say but I would guess that you want to do the test in daylight away from direct sunlight. That way you could do the test and get fairly consistent results no matter whether the sun is shining or not (unless it's very overcast of course).
    Peter
    Caledon, Ontario, Canada.
    don't get too uptight about getting really really accurate results.
    I don't think anyone here will tell you they can advise you to run the pool chemistry much different at 40 ppm or 50 ppm You just need to know that you are near 40 ppm and not 80 or 10.
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by brent.roberts
    Give this man a cigar! People get a bit too paranoid at test results. Some need to be very accurate (FC, TC, CC) some are ok within a small range (pH),
    some have a much wider range to be 'OK' in (TA, CH, CYA)
    michladny is offline ** No working email address ** michladny 0
    Oh, this is all good to know cause I did my CYA inside the house and placed it on top of a white piece of paper... when I had the water tested (pool store four days before)it was 53 and when I did the test a few days later (practice ) it was like 80!!!! I will wait for a sunny day and do it outside.....
    THANKS FOR THE INFORMATION!!!!
    Michelle
    waterbear's Avatar
    St. Augustine, Fl
    Actually, this test is best done outside in the shade with the tube held about waist level.
    Kannapolis, North Carolina
    Wink Re: CYA Test
    I do the test outside, standing on one leg and leaning over a brick wall, while chewing gum. And if that dont work I will slap myself in the eyes and while they are still watering do the test.
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Bowlin, thanks for the laugh! Have a great day!
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
