Results 1 to 10 of 11
Thread: CYA Test
    Caledon, Ontario, Canada.
    Default Re: CYA Test
    don't get too uptight about getting really really accurate results.
    I don't think anyone here will tell you they can advise you to run the pool chemistry much different at 40 ppm or 50 ppm You just need to know that you are near 40 ppm and not 80 or 10.
    Quote Originally Posted by brent.roberts
    Give this man a cigar! People get a bit too paranoid at test results. Some need to be very accurate (FC, TC, CC) some are ok within a small range (pH),
    some have a much wider range to be 'OK' in (TA, CH, CYA)
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
