15K and I don't remember exactly how much because I added, ran pump 12 hours, tested and then repeated until I got around 30 ppm. If I had to guess I would say about 3 lbs. And yes, granular.
How did you add it? Through the skimmer?
I did add it through the skimmer.
So, here is what I think happened.
Even though you thought you had nearly none after you did your partial drain, you may have had almost 30ppm since any amounts less than that won't register on the test.
CYA takes a long time to dissolve -- like 4-5 days or even a week. So, each day when you tested, the CYA that you had added the day or so before had not fully dissolved and thus wasn't being picked up yet on the test. So, you added more. You are guessing that you added about 3 lbs. If it was 3 lbs., that would have added about 25 more. But, since you are only guessing, it could have been more. Maybe 4 lbs or whatever.
When you add it altogether --- the maybe 30 you already had in there + the maybe 25-40 you added, it could be around 70ish or so now.
At any rate, even if it is 70 or 80 now, that's ok. Just run your chlorine levels at the needed levels and you'll be fine. More info about the relationship between CYA levels and needed chlorine levels can be found here:> http://pool9.net/cl-cya/
(Until your registration is completed, you won't be able to follow that link or see the rest of the forum while you are logged in. So, copy the link and paste it in a browser window after you log out.)
Hope this helps. Welcome to the Pool Forum, by the way!
. . . membership updated.
