Re: Need some guidance.. AGP, 'The LIQUIDATOR', Ballvalves, suction, vacuuming....
Looks ok but I probably would not of spent the money on it.. Not sure if restricting flow on the inlet side of pump is a good idea..
Why did you go with that system?
I could not find install instructions on line. If you post them we can help you better..
12x18 vinyl AG 6.2K gal; Hayward equp: 16" sand filter (spring clean up) -- Xtream 100 sft cart (after clean up) -- Power Flo Matrix 1hp 2spd pump w/ AO Smith motor
