Closed Thread
Results 1 to 10 of 12
Thread: Proper circulation in shallow beach entry
    GTakacs is offline Registered+ Thread Analyst GTakacs 0
    Default Re: Proper circulation in shallow beach entry
    I'm just in the process of having a pool with beach entry built. The builder puts a return head in the beach entry to the side shooting across the beach entry area. It is in the floor, not in the wall.
    I'm also adding a foam jet to the middle of the beach entry for looks but it should help with the circulation also.
    beary is offline Registered+ Thread Analyst beary 0
    Dec 2005
    What is a foam jet?
    Beary
    Use one of these adjustable infloor returns for tanning ledges or beach entries.
    Sta-Rite HWDSP1425S adjustable in-floor return
    Hayward SP1425S adjustable in-floor return
    Quote Originally Posted by beary
    What is a foam jet?
    It's a bubbler made by Watercrystal Fountains. http://www.watercrystalfountains.com
    baseballmom22 is offline ** No working email address ** baseballmom22 0
    Texas
    We're putting bubble jets there as well.
    Dec 2005
    Those are the kind of ideas I was looking for folks, thanks. Part of my concern was the contractor wants to put in all the same type of returns. I don't know if there is a fear of different flows that can restrict the pump or what, but I sure like the ideas you've tossed at me.
    I've asked the contractor to have each return have a seperate value at the pump incase some day one fails or leaks, then I can just turn it off. I found he does that anyway, but can these floor returns or bubblers change that design?
    Thanks again.
    Beary
    Edmond Ok
    I have not heard of having separate valves for each return at the pump. The returns are generally done in a return loop fashion so all returns are on the same pipe. Builders though have separate valves for each drain and skimmer so you can control how much of the water is sucked at which skimmer and main drain for better circulation.
    My beach entry in-floor return will be on the same loop as my other 4 returns for my pool (it's a 14,000 gallon pool approximately). The foam jet will be on its own line controlled by a 3-way jandy valve with a JVA, so I can divert some or all of the flow from the main returns to my water features (which includes a foam jet in the beach entry and two crown jets in the decking).
    Sanford, FL
    You stated that your builder isn't really familiar with a beach entry.
    Stupid question - but why would you choose a company that isn't very familiar with all the options you want on your pool?
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
Closed Thread
